Why does my rear suspension make noise?
i am from India.. &i have hero next bicycle.
whenever i drive it or when the rear suspension is used.. th e cycle makes noise like .. chooo///socho.... please help me ..
It could be that the Spring ist not tightened enough, so it could move between the damper and the big Nut. If the Damper comes out by using the Negative damping and the Spring can move, it could be that the Spring you are using is for a bigger Loading (It means that you are too light for this Spring)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,037
