メインコンテンツにスキップ
大きめのアップルMacBook Airラップトップはデュアルマイクと802.11ac Wi-Fi接続を特徴としています。
465回答 すべてを表示
締切られた回答
What is a non-obvious cause for a faulty temperature sensor?
My MacBook Air suffers from intermittent slowdowns and unnecessary fan use. I sent it to Apple under warranty and they replaced the battery and the logic board. But the problem persists and iStats shows that the temperature is reading -128 C.
It seems that Apple was right to replace the logic board which includes the temperature sensor (right?) But, why didn't that fix the problem? It seems very unlikely to have two faulty logic boards, both with bad sensors.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Run ASD, tell me what temperature sensor fails. There are many temperature sensors. One in the trackpad, one on DC in board, ones on the board itself. Sometimes the sensor fails, sometimes the sensor is fine but cannot communicate with the SMC because of bad or missing pullup resistors on a data line, corroded via, corrosion pulling down a data line, or a bad SMC.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
ASD? Apple System Diagnostics? I get codes PFM006 (fan), PPN001, and NDC001 (camera). Not sure how to to determine which thermal sensor is bad.
さんによる
コメントを追加
Louis you're right. Apparently there are also three sensors on the battery. TB0T, TB1T, TB2T.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,768
