Screen say 309640 minutes?
Why does the screen say 'Try again in 304690 minutes'?
in this case,u should flash ur phone with latest flash file,then it works correctly.....
このアンサーは役に立ちましたか?
what do you mean??
Try to hard reset ur phone however this will lead to everything deleting so take out ur sim and memory card and turn ur phone off, hold the power button and when phone vibrates hold the volume button down, this should lead to a triangle with '!' In the middle this means ur doing it right... When it does this, press...
Volume up
Volume down
Press the power button
Then volume down
Ur phone will now restart and everything should be brand new
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 1,637
