Is battery easy to be replaced?
Is it possible to carry a backup battery on road and use a simple tool, like screwdriver to replace the battery for extended use? Thanks!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
when you look at the teardown - you will see that the battery could be easily removed - but i would not do that. it looks fragile and i would prefer a mobile charging solution, i have a emergency charger that is powered by an AA battery - works great. this charger could easily modified to charge an iPhone
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 909
