Internal SD-card Reader doesn't work. How can I repair it?
Unfortunately, I have damaged the internal SD-card reader by pushing in a damaged SD-card with force.
It appears that the wire connections (to the SD-card) inside of it are torn/twisted. I have opened the Dell Vostro 3550 laptop already, and have seen that the reader is soldered to the motherboard.
Could I perhaps remove the reader's housing to fix the item?
Post an image with your question. That will allow us to see what you see.
oldturkey03 さんによる
Hi, I have added an image.
Fratzko さんによる
Thank you for the image. If you remove the housing, you may not get your SD card seated properly. I'd try to find someone that can do microsoldering and replace it properly.
oldturkey03 さんによる
