メインコンテンツにスキップ
2011年後期モデル番号A1278 / 2.4 GHz i5 or 2.8 GHz i7 プロセッサー
591回答 すべてを表示
Best HDD to replace my stock HDD
Hi guys currently im on an SSD + HDD setup unfortunately my HDD gave up last week im looking for a replacement HDD but im leaning towards the WD scorpio blue 1tb but the down side is it only has 5400rpm would that be enough?
I mainly use my HDD for symbolic linker for my media files such as photos, music and videos
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
I suspect you have the HD located in the optical drives location. If you do you HD likely died from shock. The problem here is the original HD does not have crash protection within the HD. Instead Apple has it as part of it's logic board HD SATA port.
So basically you want to locate a HD that has crash guard to replace your HD. In any case the slower RPM drive will be fine.
The other option here is to go with a SSHD unit replacing not only your HD but you SSD as well. While that may seam to be going backwards in truth it's going forward. Putting the SSHD in HD's location will give you a faster conduit as the HD SATA port is faster. In addition, the power requirement will be less giving you more battery time. Lastly, the performance will in fact be better than the two drive setup. Checkout Seagate's laptop SSHD's we have quite a few in use and love them.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Bluerthanlou さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 148
