メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3531回答 すべてを表示
Touch ID working but home button is not
Hi,
I'm having an unusual issue with my 5s, as the description says, my Touch ID works without issue, however the home button itself is not working. It gradually got worse, going from working 50% of the time to as it is now, which is never. I'm using assistive touch to navigate out of apps and such now, and like I said using Touch ID now problem. I wondered if anyone has come across this issue before and if there is a fix? (That maintains TouchID functionality). Funnily enough the problem developed one year and two days after I purchased it, go figure.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
4件の回答
最も参考になった回答
I would take it to Apple, once you replace the home button touchID is lost, forever
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi David, I have been into the Apple Store, was quoted £100 for the repair, so wanted to check here to see if anyone had come across this before and if there was a fix (that maintains Touch ID functionality) I know a replacing it (when not done through Apple) will lose Touch ID (which I'd like to avoid). Also should probably note I have tried various resets on the device, pretty much everything bar opening it up.
さんによる
コメントを追加
Hello, has a solution ever been found with this?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello,
I have the same problem.
I changed my battery yesterday and now my home button is not working... But touch ID is!
I was thinking to the home button plug, but it seems not damaged... Everything looks ok but it's not working...
Does anyone have an idea?
Many thanks!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
plug your charger on your iPhone and keep pressing the charger in the port NOT TO HARD at the same time press the home button.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks for the tip but not working in my case :(
さんによる
コメントを追加
回答を追加する
Sean さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,759
