IC Charging Chip for iPhone 3G
Hi all
my iPhone dosent charge ? they are telling me that the IC chip need to be change,witch its not available in my country , can u order it throw this website ??
thanks
この質問は役に立ちましたか?
Hi all
thanks
この質問は役に立ちましたか?
Who is telling you that?
in most cases of the non charging iPhones is the fuse toasted and not the charging ic
those kind of parts are mostly sold on ebay and some cell phone oriented websites. and of course - directly on some chines pages.
the prices are horrible, you will also need special tools to do that kind of repair. the minimum would be a hot air- or better an infrared soldering station.
このアンサーは役に立ちましたか?
dose that chip has any special name for the iPhone3G ?
there are 2 power related ic's on the logic board. one is the infineon smp3i - ebay: 160380332912, 360208665590 & 360274082574 and the other one is the NXP power management ebay: 360274631797, 360208338649 & 360209947800. search for iPhone 3G power supply ic and you will find both types
Hi, is there guide anywhere on how to change the fuse and where to buy it? i have looked everywhere but no info!
Thanks
このアンサーは役に立ちましたか?
The fuses are Soldering Surface Mount Technology Components (SMT) and are not easy to replace. Some info on here and here with some interesting ideas right here.
For the availability of those fuses, you can check ebay.com or Mouser.com Good Luck
You can try just a thin wire or solder bridge as well
replacing any fuse with a wire is a REALLY BAD idea!
karim, is this the same phone as on here No Power, No Charging, No iTunes
Hi oldturkey
i just asked this question about the fuse on this post
the other post is a full explanation of the problem, sorry if this is double posting??
I have tested all the fuses and they are all ok so problem is not there
Best regards
このアンサーは役に立ちましたか?
karim, just delete these comments/question so that it wont get confusing....and you get more people looking at your question. I am working on a solution...
For resuming my 3gs 32GB iphone they say that it has to be replaced...so can i buy from this ..
このアンサーは役に立ちましたか?
Is it necessary to have a hot-air soldering iron? could you just fit it and glue it down?
このアンサーは役に立ちましたか?
No you can't. Glue is non-conductive and will not last.
I mean put it in position and hold it there while adding some hot glue to the edges to keep it in place. Sounds tricky, is there anyone who would do this for me for some money?
Cheers
Leo, it needs to be solder to fulfill its functions. Sorry, glue is not the answer for a proper fix. Depending on your geographic location, I'd suggest you find some professional help to solder it for you.
Ok thanks I will do that.
Before spending a fair amount of money is there a way to make sure that the power IC is the problem? The fuses are not broken
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,337
