Why is my screen constantly just flickering
When I switch my psvita on and slide it down on the start screen all it does is flicker it like the home button is being pressed continuously. Every time I hold down the home button it stops flickering if I let to of the home button it carrys on flickering please can some one anwser back and also the power button dosenT work at all
I have thus same issue PLZ HELP ITS ANNOYING
MarkLord さんによる
Hi did anyone find a solution to this?
Christo さんによる
When you say home button, I'm guessing you mean the ps button? Not the action button?
iMedic さんによる
That is correct yes, the screen flickers on HOME SCREEN all the time, as if the ps button is pressed continuously. I did take it apart and can confirm that the ps button is not stuck nor touches the pc board.
Christo さんによる
Since you can open it and have had issues in that area. Chances are one of the PCBs in that area is damaged. Take a good long look at the circuits in that area and see if anything is damaged, raised, burnt or disfigured in any way.
Andrew Fillhart さんによる
