メインコンテンツにスキップ
Repair guides and support for your Mitsubishi TV, no longer produced by Mitsubishi Electric.
118回答 すべてを表示
Blinking green light after power outage on Mitsubishi WS-55511 TV?
My TV won't turn on after a power outage. I just have a blinking green light.
Will the fix described for "Repairing Mitsubishi WS-65511 Blinking green light" work on my older model?
Do I use the same 1000uf 16 volt capacitors that answer indicated? Where do I buy them since Mitsubishi doesn't have them on their parts list?
Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
Jeanie Kansas, yes I would suggest that you replace the caps. You can get those from compnaies like Mouser.com or Digikey. com as well as many others. the blinking green light can also be caused by the DM module's EEprom is intermittently bad.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi,your tv needs the dm power board repaired,we do this repair from e b,ay.search for listing #330700000004.on main search bar.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jeanie Kansas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 530
