Swap screen in lenovo with higher resolution
I have got Lenovo G510 with 15,6"1366×768 and I would like to replace with screen with 1920x1080 resolution.
Is it possible? Do I have to change lcd cable or just swap screen?
mateusz, only if you find a panel that is supported by your firmware, as well as your hardware. The pinout of the connector on the LCD panel must correspond with the connector on your logic board.
このアンサーは役に立ちましたか?
Ok,could you write more information? What should I check? If I will find screen which was got the same connector in the same place will it work?
Could you tell more? How could I check it?
It can for as long as your BIOS can read and access it. It will be a bit of a trial and error...
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 206
