メインコンテンツにスキップ
AppleのiPad AirのWiFiモデルのバージョンはモデル番号A1474、スペースグレーと、シルバーがあり、カスタムA7プロセッサーが装備されており、容量は16、32、64、128GBがあります。
295回答 すべてを表示
Touch screen doesn't work,No water damage, No connection problems.
Hi. I have iPad Air 64GB but as I describe this title, touch screen doesn't work.
I mean cannot recognize any touching operation.
I open it but it doesn't have water damage, there are no connection problems. (because screen works well on the other iPad Air)
Strange thing is occasionally it works well for very short time then within 1 min back to initial condition.
How can I fix it? and where I have to change into new parts?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
1 件の回答
最も参考になった回答
So you took two iPad airs apart? When all the iPad probably needed was a restore
Was screen damaged or was it just the touch that wasn't going?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hello. Thank you for your reply and your suggestions.
well as you mentioned, did all before open it. screen was beautiful condition and a little while it worked normally but suddenly, the screen became out of work. connections have no problem at all....
So, I open it and the screen is now working well on the other iPad Air.....
I wonder if it has program in logic board.....should I change into new board?
さんによる
Sorry I misunderstood.
well, I have 2 iPad Airs and one (iPad A) had broken screen so, I removed broken parts from it.
iPad B has problem now. it was looks good but as i explain touch screen doesn't work.
now, I restore iPad A by using iPad B parts and it is restored perfectly.
I have parts to restore for iPad B already but I need to solve initial problem. Do you have any idea to fix it?
さんによる
コメントを追加
回答を追加する
Jonathan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,526
