Why won't my phone turn on?
My phone battery was empty so the phone turned off. After being plugged into the charger all day, it still won't turn on.
First at all, try to plug your phone into the charger. If it doesn’t turn on and begin to charge within a couple of minutes, the battery may be dead. If the battery is dead, it will need to be replaced with a new battery.
Second, if the problem persist, it is possible that the phone is turned on, but the display isn’t functioning properly. The backlight or the LCD will need to be replaced.
If the phone still not on, the problem is probably that the logic board is bad and needs to be replaced.
このアンサーは役に立ちましたか?
I have a samsung fame lite. It fell but now it can boot up. ALL it does is just the logo samsung blue circle turning but does not boot up
このアンサーは役に立ちましたか?
Even so it will not turn off
why phone dont open n restrating everytime solution samsung galaxy fame
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 725
