Phone is dead after not using it for a long time.
Phone is dead after not using it for a long time,
but still charging.
I can't reboot it, I can't restart it.
What can I do?
Many thanks
Do you have a Voltmeter to check if the battery is holding a charge? if so disconnect the battery then test the positive and negative post. The voltage should be printed on the battery.
I would say though that you let your battery stay dead for too long and needs to be replaced, just as if it was a car, or powersport battery. All batteries if they sit to long can not be revived.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,259
