Why won't my projection clock sync with the Atomic Clock?
On my recent visit to California from Canada, I purchased a projection clock. It does not sync with the Atomic Clock.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
You might try resetting your clock - there's a reset button behind the battery cover. (See attached guide)
このアンサーは役に立ちましたか?
I may try this. I have a different model. I just reset the time after time change. Can't see dumping the clock when it still works. Just doesn't sync with the master clock.
過去 24時間: 0
過去 7 日: 4
過去 30 日: 15
今までの合計 2,344
3 件のコメント
After re-reading the users manual, I discovered that only Eastern Central, Mountain, and Pacific time zones are available. This clock does not function properly outside the continental United States.
Kathy Rowley さんによる
Projection Clock RM318PA Troubleshooting.
Kathy Rowley さんによる
I am located in Eastern zone of Canada, still it doesn't work!
Salem Hendow さんによる
