Craftsman Lawn tractor DT 3000 Model
The shift lever does not do anything. When I shift it into 1st gear or any other gear it does nothing. Shifting lever feels like it is not engaging. How do I fix it or what could be wrong?
I'm not quite sure what you mean by the shift lever ... does that control the speed of the mower or is it to make the blades work? I wonder if it is your clutch cable? My spring broke that engages the blades. It is a long cable that goes from the lever to engage the blades down to the deck. The handle to engage the blades will not have any tension, it is just loose. See if the spring is hooked up properly on the deck, it might have broken but looks like it is still all attached. The videos on youtube and also repairclinic.com show how to replace them.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 381
