Why won't my headlamp stay pointed in the direction I want?
My headlamp isn't staying in the position I place it in. What is causing this problem? How do I fix it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If your headlamp fails to stay pointed in the direction you want, the mount assembly may be loose.
Loose Mount Assembly
The single screw and bolt holding the mount assembly together may have become loose. If so, you can remedy this problem by tightening the screw using a phillips screwdriver.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 109
