Tape cassette is not working after being installed and will not print?
I hit the print button and my label maker made a noise, won't print and when it did print, it separated.
Power off the device, check to see if proper tape was loaded. Also if the tape cassette is the proper size, then check to see if the tape cassette is loaded correctly into the label maker. Lastly check if tape is entangled in the machine, or the top and base layers of the laminated tape are misaligned.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 389
