メインコンテンツにスキップ
MacBook、MacBook Pro、MacBook Air用のAC電源アダプタです。引っ張られても安全に外れる整列式の磁気コネクタを採用しています。第一世代 (2006-2012)のMagSafe充電器は、コネクタがやや太いL字型になっています。45W、60W、85Wの3種類があります。
65回答 すべてを表示
締切られた回答
magsafe 2 replacement not charging
hello guys my magsafe 2 replacement don't work properly.
when i plug i get green led but after 2,3 second he turn off and start looping without charge the battery.
seems like not the connector... bad quality replacement?
its just 8mouth old.
any help is appreciate
really thx
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi lapo,
If there's no kind of warranty on your adapter, and the company you bought it from can't help you out, there's no harm in opening it up (if you're just going to throw it away). You may be able to do some exploratory surgery by checking out our Apple AC Adapter guides. Best of luck!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
yeah i will try to change the cable in a old 85w... thx
さんによる
コメントを追加
If you are trying to contact iFixit because you bought the part from them you're in the wrong place. This is the volunteer iFIxit self-help forum, we are not affiliated with iFixit in any way. Use the link at the bottom of the page to contact iFixit customer support.
If you did not buy the part here I would suspect your battery before a part that worked fine for 8mo.
If this answer is acceptable please remember to return and mark it accepted.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
off course not, just buy on ebay.
with original magsafe 2 of my girlfriend everything is work fine.
さんによる
You get what you pay for, and pay for what you get... cheap is . . . cheap I guess you'll get a replacement somewhere else?
さんによる
i will buy original, the price is 4 time. thanks
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 322
