メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459回答 すべてを表示
My camera keeps saying camera failed. How do I fix it?
Camera keeps saying camera failed. How do I fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 194
30 件のコメント
Why Samsung phone camera keep saying camera fail every time I suppose to have best camera because my phone is note 4
さんによる
Turn your phone completely off and then turn it back on
さんによる
How long do we turn off our phone , for my camera can work again ?
さんによる
I restarted it then it works, but after a while it failed again..
さんによる
25件以上のコメントを表示
コメントを追加
11件の回答
最も参考になった回答
I was facing the same problem. what did was i just opened the back cover remove the battery and sim the replugged them again.
issue resolved
このアンサーは役に立ちましたか?
スコア 23
21 件のコメント:
thanks imranalam1977. tried most remedies, but none helped, until yours. Thanks again, my camera is now functioning.
さんによる
Sukriya Imran bhai . Your suggestion worked .
さんによる
This is the only suggestion that worked. Thanks
さんによる
You're the best! Thanks a lot
さんによる
Thank u imranalam my phone camera is now working ...........th nd alot
さんによる
16件以上のコメントを表示
コメントを追加
Hi,
- First of all try this: Open Camera app from the "Application manager" and do "Clear data", then restart the phone.
- Second: Do a Factory reset (of course save your data!).
- Third: Reinstall Android OS.
If this not help you, you have a hardware problem. You need to change the camera.
Also you can test the camera from the Hidden / Test menu.
Enter this code at the dealer: *#0*#
Samsung Galaxy S4 - Secret Codes, Service / Test Menu
Regards
このアンサーは役に立ちましたか?
スコア 15
3 件のコメント:
Wooow thnk u soo much
さんによる
i did rreplace the camera with a working one but that problem still exists
さんによる
Hello, after testing my camera using the code above, I observed the camera hardware is working well but the app is still not working even after factory reset.
Any suggestions please.??
さんによる
コメントを追加
In many cases, the 'camera failed' error occurs because the Camera app has got itself into a bit of a mess. You can often solve that with a fairly simple bit of housekeeping. Go into Settings > Applications Manager and then swipe left for All Apps. Scroll down to the Camera app and tap on it. Now tap on Force Stop, then Clear Cache, then Clear Data. Don’t worry: this won’t delete any of your photographs, but it will delete your camera’s settings so you’ll need to set those again. Reboot your phone and see if that worked.
If it didn’t, step two is to clear the cache partition. To do that, turn off your phone and then press and hold Volume Up, Power and Home. Once the phone vibrates, let go of Power but keep the other two buttons pressed. Once you see the Android Recovery screen, navigate to Wipe Cache Partition using the volume down key and use Power to select it. This won’t delete your data but it should reset the app’s cache, which should solve the problem.
Nothing? Time for the nuclear option: a factory reset. Make sure you take backups of anything you need first, as this will return your phone to factory-fresh condition without any of your stuff on it.
Still no joy? Dump the app altogether and try the excellent Google Camera (KitKat or later required) or one of the many wonderful third-party camera apps out there. Read the reviews carefully though: some camera apps are better than others. There's no point in installing a duffer.
このアンサーは役に立ちましたか?
スコア 8
3 件のコメント:
Thanks it works
Now my camera opened
さんによる
Thanks it worked
さんによる
thanks po , my camera works now
さんによる
コメントを追加
Restart your phone then it should work
このアンサーは役に立ちましたか?
スコア 6
3 件のコメント:
But I've done what you speak
YES NO CHANGE
さんによる
Its a Samasung Tab S tablet - I have no access to the internal bits ...... formatted more than 10 times still no change.....any help?
さんによる
i did it all , but it didn't work
さんによる
コメントを追加
Go to phone service to change your camera maybe its work . if you want to see is it working, yo need to try...
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
Turn off the Smart Stay feature under settings, then reset the phone. This will fix the problem.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
At first flash this phone
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Many time i solve this provlems
さんによる
コメントを追加
Hi,
I just powered off my phone, removed battery, removed sim, put it back inside , turned the phone on and the problem was resolved.
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
Just remove your Sd Card and unplug battery and sim card and insert again . Its helpful in some conditions
さんによる
コメントを追加
I have the same problem with my Samsung 8. However, I know what the problem is, I need the super tiny “shaft that he warns about when replacing the front screen.
I took my phone apart, replaced the screen/digitizer and must’ve lost the little piece that goes in the slot at the top (middle r) before you screw the last inner cover down.
Would not having the “shaft” be the cause of Camera Failed? Can I just use a small piece of metal?
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
This “unfortunately camera has stopped” error is just a system bug that is not a big issue if you have stock Android installed. Usually a simple restart or clearing cache will fix this error.
Method 1: Restart phone
Well, this is a very straightforward step that could easily fix the camera has stopped error on your smartphone.
Method 2: Clear cache and data of your Camera application
Most of the time, the application cache may cause this error. To fix it, simply follow these steps:
  • Go to Settings >> Apps (or application manager) >> Swipe to go to “All”
  • Now scroll down the list of apps, and tap on “Camera”
  • Tap “Clear Cache” & “Clear Data”
  • Now restart your smartphone
Open the camera app and check for the error.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Maybe the subject was moving too fast. Today I was trying to take a picture of a grain elevator along the interstate. The guardrail posts and signs and other stuff on the road was passing the camera at 75mph and I kept getting "Camera failed". Later, in a McDonald's restaurant here everything was either moving slowly or standing still, I took a couple pictures with no problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Michelle さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 50
過去 30 日: 235
今までの合計 290,820
