メインコンテンツにスキップ
The Moto G is Motorola's economically priced phone. It has all the features one could want in a smart phone, for half the price. Model numbers XT1032, XT1033, and XT1036.
86回答 すべてを表示
Why am I not getting sound from headphones when plugged in phone?
When I plug my headphones into my Motorola Moto G headphone audio jack, no sound is coming out of the headphone speakers. What could be the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I was watching a video on my laptop and it was working fine and after that there was no sound please help
さんによる
コメントを追加
3件の回答
最も参考になった回答
First check and see if your phone is under warranty. If not under warranty check the volume settings. If volume is set correctly try turning phone completely off to reset. Next try replacing the headphones or accessory you have plugged into the jack. If there is still no resolution the jack may need to be replaced.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
put phone into safe mode then delete all apps then restart phone then if it doesnt work do it again but delete all apps that you have recently downloaded
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
or dip jack tip in slight water dry a little insert again make sure your not drowning the piece your just trying to restore the conductivity of the jack itself
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Matthew Byram さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 9,106
