メインコンテンツにスキップ
Released 2001 by Thomson multimedia Inc. The RCA RP3715A is a radio alarm clock equipped with AM and FM radio frequency reception, an audible alarm clock function inclusive of snooze, nap, and sleep settings. This device has a memory holding system which is powered by a 9-volt battery.
4回答 すべてを表示
Why can I not change the radio station?
When I go to change the radio station, the tuning wheel has limited range. It does not allow me to turn the tuning wheel beyond a given radio frequency.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
If your tuning wheel has a broken gear or is worn, it might need to be replaced. A worn tuning wheel will can cause the limited range. The gears connecting the tuning wheel and radio frequency doesn't allow to past a certain point. Replacing the tuning wheel will allow for the gears to turn effectively.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
joseph さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 108
