メインコンテンツにスキップ
2014年6月に発売されたSamsung Galaxy S5 Activeのモデル番号はSM- G870Aです。このデバイスの修理は大規模に渡り、ヒートガンとスマートフォン専用のツールキットが必要です。
75回答 すべてを表示
I broke camera cover lens? how can I buy and repair it
please help me as soon as u can
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
3 件のコメント
There's a guide linked at the bottom, but it is for replacing the camera and is unclear if the lens can be access without disassembling the front of the phone. Is the S5 Active lens (only) glued on from the outside or is it an assembly that must be accessed from the inside of the phone? I'm also having trouble finding the lens for purchases, is it the same as the regular S5 lens (one of the G900 models)?
さんによる
Could I see a picture of what it looks like broken?
さんによる
my mobile sumsung j5 this mobile broken by back cemera lens its buy or repair iam see any purchese the product
さんによる
コメントを追加
3件の回答
最も参考になった回答
We just saw your post and we have determined how to replace the camera cover lens. First you will want to remove the back cover to access the cover lens. Surrounding the camera lens is a gloss black square structure. Use a guitar pick and run it around the edges to remove the glue. Once you have that removed the cover lens is just glued onto the phone. Use a guitar pick to then remove the main cover lens. The cover lens is also glued onto the phone. We are currently in the process of writing a replacement guide for this such case. We will have it posted shortly. Please ask if you have any further questions.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
Where can I buy the replacement for a cracked rear camera lens on the Active G870A?
さんによる
Very helpful, is the tutorial available yet?
さんによる
コメントを追加
Samsung Galaxy S5 Active Rear-Facing Camera Replacement
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You can get one here.
http://www.ebay.com/itm/291334444397
このアンサーは役に立ちましたか?
スコア -1
5 件のコメント:
this is for s5 not s5 active, any other suggestions where to get s5 active lens cover?
さんによる
I don't think you can purchase it separately. You have to purchase the "G870A Chassis Housing Camera Lens".
さんによる
I have been using the s5 lens and cutting it down with dremel and loca in place. best i can offer people till they have parts.
さんによる
That would probably work, but you lose the water resistance, so it depends on what's more important. The part is available, but it's a complete assembly.
さんによる
So that len s5 is alike len s5 active too?
さんによる
コメントを追加
回答を追加する
hduynam11299 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 15,213
