My phone doesn't pick up any connection?
My phone doesn't pick up any connection ?
Make sure you have set your device to use the correct network type. If your subscription plan does not support the LTE (4G) standard, you must select a network type other than LTE (4G). If necessary, contact your operator for more information about your subscription and the network types supported.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 265
I have the same problem, not solved although I had sent in warranty.
It is not a matter of software, let alone solved by setting the values of the network.
For me it is a matter of telephone module, but in my opinion we can't solve by itself or with homemade tools.
losoom さんによる
