メインコンテンツにスキップ
Released on February 25th, 2013. 10.1" Tablet with Android Operating System, ARM Cortex A-7 Quad Core Processor.
28回答 すべてを表示
Why am I having difficulties with the Battery life?
After I charge the tablet, the actual Battery life is much shorter than the estimated one.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント:
After doing some research, I believe that I have found the answer to my own question.
First, start by checking the Settings on your device. You can also proceed to check for water damage as well. Additionally, you can check the internal wiring of the device.
Lastly, if none of the previous steps work, click on the Battery Replacement Guide and follow the steps outlined.
さんによる
コメントを追加
1 件の回答
First, start by checking the Settings on your device. You can also proceed to check for water damage as well. Additionally, you can check the internal wiring of the device. Lastly, if none of the previous steps work, click on the Battery Replacement Guide and follow the steps outlined.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gabriel Delgado さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 133
