How do I retrieve lost pictures from corrupt Kingston USB drive
How can i retrieve data from corrupt USB drive
You may not be able to do so. It is important to not write anything back onto the drive.
There are a number of data retrieval apps that depend on what OS you're using.
The process is that you make a copy (if possible) of the data onto a good working backup volume and then retrieve data from there.
As a Mac user I have had good results from DataRescue3, and also from Cardwiper an app. that has a retrieval function.
If this answer is acceptable please remember to return and mark it accepted.
このアンサーは役に立ちましたか?
Pen drives are generally FAT formatted.You can recover your data using any windows recovery tool.some are Recuva,Stellar windows data recovery,RStudio....and more.In case pen drive is HFS/HFS+ formatted,you can use any OSX data recovery software.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 307
