メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
3282の回答 すべてを表示
Cant Activate iPhone 4 Error 0xe8000004
Okay, so I have an Iphone 4 that I KNOW was working. I switched phones and gave my old phone to daughter's boyfriend. He opened an account with the same provider, I know this phone is not jailbroken, nor is it a provider issue. When I stopped using this phone I wiped it to factory, and nothing has been done to it since.
I do know the wifi is not working on this phone, but it was activated in the past without wifi and worked fine (just expensive).
I put in his SIM (SIM has been tested in a working phone and works fine) but once connected to Itunes to complete activation the error in Itunes reads "The Iphone could not be activated because an unknown error occurred (0xE8000004). Please try again later."
Please help!
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 28
コメント:
please eror 0xe8000004 hlpz my master////??
による
コメントを追加
7回答
選択されたソリューション
I fixed it!!!
Step one, down graded the IOs by following these steps to the letter http://www.geeksn0w.it/GeekGrade/downloa.... I had to do it twice ans 5.1.1 was too far back and failed, but 6.0.2 worked great.
Step 2, activated phone through Itunes.
Step 3, did an update to current software using Itunes to get rid of the tethered boot.
Works like a beauty - except for the broken wifi, but that's another issue for another day!
この回答は役に立ちましたか?
スコア 27
コメント:
Hello, i i have managed to downgrade to 6.1.2. Tethered boot, am wondering if i upgrade via iTunes just like you did will i encounter the error again. I have read in other forums and most guys say its a hardware problem with WIfi and bluetooth. I don't want to do the downgrade again since its a tiring process. Did you upgrade work on the latest itunes or 11.0
による
Keep trying, check out my solution at the bottom, I am on iTunes 12.4.1.6 but used iTunes 11 with patch for the pwned downgrade and iPhone 4 is now running stable on iOS 7.1.2 don't give up! I tried to get it to work for over a year now so it is a very exhausting process but not all is lost, the 3Gs new bootrom story is much more complicated but I might have the solution one day
による
Thanks it worked actually, am on 7.1.2 i just upgraded to latest iTunes then i chose update instead of restore. No errors on activation it passed all the steps. Bluetooth and wifi cant be activated which is a hardware problem. If fixed everything can work.
による
sorry I'm not the best in this... but to be sure before I follow the steps: when I make the downgrade to iOS 6 or 5 tethered and then I activate my iPhone 4. Can I upgrade using the latest iTunes and I won't get the error again? Or I have to be on iOS 6 for ever... thank you so much
による
@matimillan29 yes you can update to the latest iOS 7.1.2 with the latest iTunes version 12.4.1.6, everything should still work :)
による
表示する 3 他のコメントを
コメントを追加
If wifi is greyed out then phone will not activate even tho it says connected to iTunes it still won't accivate because of the greyed out wifi. Until Apple stop signing firmware for the iPhone 4 I'm afraid it's bricked til then
Had a iPhone 4 with same problem and spent a full day trying to figure out with no joy
この回答は役に立ちましたか?
スコア 1
コメント:
I don't even see the wifi - its coming from a new set up - all that is visible at the top of the screen is "no service" and the battery meter.
Would downgrading the firmware help with this issue?
による
コメントを追加
You can downgrade but if the shsh blobs weren't saved then you will have to downgrade to a teathered jailbreak..
It's possible to do but will take a while as numerous programs are needed on a laptop
この回答は役に立ちましたか?
スコア 0
コメントを追加
This worked for me eventually, I flipped between these instructions and these - https://youtu.be/OaaMtnqk810
I had to download to version iPhone iOS 6.1.2 - I also couldn't get in dfu mode and had to use this different method -https://discussions.apple.com/thread/526...
Took me all day - nightmare!!
Thank you!
この回答は役に立ちましたか?
スコア 0
コメントを追加
OK guys since y'all know your stuff I will let you know I have FINALLY just FIXED mines after oh so long, reading through all of your methods & issues, well turns out that it is a hardware over software issue so after downgrading, upgrading so many times after another as you have probably done so already, I noticed that WiFi will come and go every time I booted on the latest version iOS 7.1.2 & of course I tried to activate it since I know it was unlocked already but still iTunes came back with an error that there was something wrong with my iPhone & to take it to a service center which some of you might be familiar with already, so since I noticed that WiFi coming & going I decided to leave it on my favorite iOS 5.0.1 GeekGrade .ipsw and so happens today I tethered booted but WITHOUT SIM CARD & SIM TRAY everything came back WIFI +CELLULAR+ BLUETOOTH :D that is what has just worked for me hope it helps anyone ;)
この回答は役に立ちましたか?
スコア 0
コメント:
what is a tethered boot??
による
yes it was a teathered boot
による
コメントを追加
The aptoide app for iphone are likewise like android app. Aptoide Download that offer the discernment in the individual's hand to handle their download.
この回答は役に立ちましたか?
スコア 0
コメントを追加
Aptoide iOS is third party application used in apple AppStore and google PlayStore. Aptoide iOS is use by over 20 million members around the world.
この回答は役に立ちましたか?
スコア 0
コメント:
Thanks for sharing the article on iphone 4. Now i have a software for iPhone called as Aptoide. Aptoide iOS is best platform you should check it out.
による
コメントを追加
回答を追加する
Jen J さん、ありがとうございました!
統計データを表示:
過去 24時間: 5
過去 7 日: 39
過去 30 日: 191
今までの合計 78,591
