Why won't the cassette player play my tapes?
I put the cassette in the cassette player, but it won't play. The volume is turned up.
I am not mechanical. Can you suggest someone near Ft Washington, PA or Ft Lauderdale,Fl who can fix cassette players?
この回答は役に立ちましたか?
My NAD tape deck will not start. The power is on, when i press PLAY button it keeps knocking and knocking, tape rolls bouncy and knocks all the time. Once it managed to play and after that every time i stopped it and started PLAY again that was ok. After a couple of hours when it was switched off I tried again and knockings have come back and it won't set off.
この回答は役に立ちましたか?
I also have a non working cassette player. Only had it fitted last week (second hand, not come back there) and it was working but now when I put the cassette in, the radio stops as it should but the cassette doesn't play and I can't hear the motor turning but it still fast forwards and rewinds so no idea. Gutted as it's a 1991 car and I don't want to put a cd player in as I prefer the retro originality of the radio cassette. Any help would be appreciated
この回答は役に立ちましたか?
need a belt for the cassette player
この回答は役に立ちましたか?
Hi @joejefferson ,
If your device is a Sony CFD-8 then this link may help.
The 2nd answer in the link might be the quicker option.
Here is one I found if it suits you and you're in the USA of course.
My cassette player is jammed and it's like the tape can't run through it. Then it sometimes unwinds the tape and it gets caught in the wheel. How do I fix this it's my dads and I really want to fix it ! Help please
過去 24時間: 4
過去 7 日: 14
過去 30 日: 88
今までの合計 68,663
Can someone tell me where I can have a cassette player fixed?
Selma Tolins Kaufman さんによる
