メインコンテンツにスキップ
Nintendoのハンドヘルドデバイスは2011年2月に発売されました。モデル番号はCTR-001です。
455回答 すべてを表示
What screwdriver should I use?
Hello there, I will be taking apart my 3DS ( Wifi card problems ) and I've been doing some research and it seems that the #00 Screwdriver which people recommend MIGHT strip the screws. Is this true? and if it is true what screwdriver should I use?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Alex, any screwdriver "MIGHT strip the screws". That is where the importance of good tools comes in. I prefer to use quality tools only, and invested in a set from here. The chances are slim to strip screws with the right set of tools.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I used the smallest phillips screwdriver I had, and it worked fine but you have to press down firmly on them to make sure they grip tight enough without stripping.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
if it they arent coming dont force them. Apply a drop and i mean a tiny drop of oil (wd-40, pb blaster, trumpet oil, car oil, whatever). you need to let the drop of oil work in there for 20 seconds or so and try again. it is best to work the screw in and out meaning tighten and loosen it to get it free and even after its free you might have to tighten and loosen to work that oil in there. It will come out like this with patience
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Alex さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 532
