メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1232回答 すべてを表示
締切られた回答
Where do I get the inside LED light for cheap?
My IPhone 5c is water damaged. I recently gotten the phone given to me and it was water damaged when I got it cause I thought it would be fixable. I went to a guy the fixes them and he said it'll cost about $200 to fix it, because it's risky. I can't send it in because it'll cost more than he's offering, but that's a little too pricey for me. I can't find anywhere online on where to get the inside LED light for the screen, because it's what brings up the picture on the phone. I recently bought a battery thinking that, that was the problem and he explained that it wasn't the cause.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Sara Tackett, just to clarify. You bought a water damaged phone to have it fixed by someone else? You want to change the LED inside the display? This is just for clarification purpose. My answer to you would be that you will be better of to replace the complete display, then to attempt to change the LED. Right now you are going by the assumption that it is the LED that does not work, your problem may actually be a problem with the backlight circuitry on the logic board etc. You may need to do more troubleshooting.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 918
