Why my tablet won't come on
It stop coming on at all I charge and charge it! It still won't come on at all it won't even show a screen.
This is a normal error with these tab's.
There is an easy fix, that dont always work: press and hold powerbutton and soundbutton simultaniously for 5-10 seconds. If it works you will see the light in the screen come on.
If this dos'nt work you are a little unlucky, but there is hope...
The solution is not something you should fix yourself, because it can cause you to loose your warranty. (And it is a case that your warrany covers)
BUT however, if you dont care about warranty, or you do not want to wait the time it takes to send it in to get it fixed, you can open it up, and disconnect your battery for a few moments, and then put it together again... This wil fix it straight away... simple and stupid :)
Good luck :)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 55
Please help me!
Clarissia Cotton さんによる
