メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
締切られた回答
Finger print recognition failure
Hello Comrade.
I have an iPhone 5s 16gb gold. After replacing the home button with fingerprint recognition it doesn't seem to recognise any finger print. I cannot set any finger print or lock my device with the fingerprint security. Who might be knowing a fix to this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
最も参考になった回答
You cannot replace the home button on the 5S and still use the fingerprint sensor.
The original sensor in the button is tied to the phone.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Robinson M, that is exactly what happens when your replace the home button. The touch ID sensor is designed to be secure and it is uniquely paired with each specific phone. There is no way to restore that particular function. Read more about that on here. and on here as well. "unique logic board in each iPhone 5S and the fingerprint data is stored on the A7 chip". Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Old turkey..Thank you for the info..Thank you Aceman..Helped me understand
さんによる
コメントを追加
Update on this issue: Apple can actually fix this by replacing the display assembly, they are able to re-provision the security pairing. As long as you have warranty or willing to pay about $100, you can get it fixed.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Is the id in the actual button, or is it in the resistors mounted on the flex?
If its on the flex, would it be possible to transfer these over?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
This has been asked before and it is all basically too delicate - you would end up destroying it either way.
I wonder if Apple themselves are able to re-pair sensors and motherboards ?
Surely ?
さんによる
Yeah...for the same price as a new phone they would!
I can imagine them pairing everything in the future :(
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 241
