メインコンテンツにスキップ
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
N7: Won't charging even though charging icon shows it is charging!
I use it since 2012 with no issue. However starting few months ago, the battery is draining while it is being charged. I use the original charger and usb cable, swapping it with my Nexus 4 charger and cable gets the same result. Now the only way to charge it is by opening the case, disconnect the battery cable and charge directly the 2 cells battery as described here.
Asus repair center told me that the motherboard needs to be replaced and will cost me $160. So instead I just bought the replacement motherboard from ebay that costed me $18 and replace it myself using this guideline.
Unfortunately the new motherboard doesn't solve the problem, it is still not charging. Now my question, which other replacement part that likely will solve this problem: motherboard flex cable, audio and usb port charger flex cable or the battery?
Appreciate for any advice, thanks..
| Problem solved. Replaced the usb port charger flex cable. Cost $14.
| Follow this Guide
Nexus 7 I/O Assembly Cableの画像
ガイド
Nexus 7 I/O Assembly Cable Replacement
難易度:
中レベル
20 minutes - 2 hours
Nexus 7 Motherboardの画像
ガイド
Nexus 7 Motherboard Replacement
難易度:
中レベル
30 minutes - 1 hour
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
bhai go to hole sale shop where you can by charging penl after that fix it first in charging base plus then - wire apply to charging point
さんによる
コメントを追加
1 件の回答
ベストアンサー
Try disconnecting/reconnecting the battery, shouldn't be a problem for you since you replaced the motherboard but here are directions: Nexus 7 Battery Replacement
This worked on a Google tablet that would only charge when it was off and a Nexus tablet that wouldn't charge.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
suhendro さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,038
