Mac mini with 256GB SSD Upgrade with HDD possible?
I want a Mac mini with 256 GB SSD Buying. and this upgrade later with a HDD. Is that possible? And how high must be the HDD?
While past Mac Minis have featured two SATA ports, allowing users to upgrade their base model with an extra hard drive, this year we only get one.
However, this empty socket over here may well be a spot for a PCIe cable, enabling the installation of a blade SSD.
More on this once we get our hands on a Fusion-equipped Mac Mini.
If this answer is acceptable please remember to return and mark it.
このアンサーは役に立ちましたか?
the hdd in the device is 7mm.
このアンサーは役に立ちましたか?
but is compatible with a 9.5mm drive.
fusion drive come with a 128g pcie x2 ssd and a 9.5mm hdd.
Would also love to know if a 9,5mm thick hdd would fit in the new Mac Mini's then i could install a 2TB version instead of a 1TB
このアンサーは役に立ちましたか?
I have the same question.Wait for some one has an answer.
you can use the 9.5mm one.
Forcyy - I think its too soon to tell if a larger HD would fit or not.
@Dan look at the teardown by owc. the hdd in the pic is 9.5mm.
look at the 18th pic .
I can confirm the bay supports up to 9.5mm. As I ibetalled a WD 750gb in my Mac mini today.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,452
