メインコンテンツにスキップ
Cooler Master's mechanical gaming keyboard. Released with Cherry MX switches.
6回答 すべてを表示
Why is my keyboard not recognized by computer?
I plugged in USB cable into my computer, but my computer says that it is not recognized. It would be really awesome if anyone can help me with this by giving me some ways to solve this problem. Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
Yeah mine started not connecting to my computer after 6mounths of use. It takes power from the usb so i can use it wireless but when i try to turn it on wired mode it doesnt work for some reason.
さんによる
コメントを追加
5件の回答
ベストアンサー
Try plugging it into a different USB port.
Check that you have the correct driver for it, it may not be installing the driver on its own.
Is it broken? See if it works with a different computer.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
If plugging it into a different USB port doesn't work, try using a different USB cable. Your driver may also not be correctly installed; check this link for the correct driver. If it doesn't connect to your computer but connects to another computer, it's possible that the USB port in your computer has lost connection with the computer's motherboard; if so, you'll need to open up your computer and re-attach the internal USB cable with the motherboard. Search iFixit for instructions on how to do this with your computer. You can check the troubleshooting guide for your device for more information.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The same issue with a Cooler Master TK Storm Stealth. I made the fatal mistake of buying it, because it was a cheaper mechanical keyboard, that only just after a year has started to malfunction. I could buy a much better CPU if I would buy an usual one, now it's to late. Cooler Master it's excellent in cooling devices, computer cases and power supplies, but have no idea howto make a reliable keyboard or mouse.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The problem is the usb port on the keyboard itself. You have to dismantle the keyboard and solder the pins better. Had the same problem with my wacom intuos 4 too. Apparently robotized welding isn't meant to handle such forces of connecting and disconnecting at any pressure.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a Lenovo keyboards. It was working 100% Raeplaced hard drive. While loading drivers it bomb out on me and 3 days now. Cant get the keyboard to work?????
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sukhyun Baik さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 34
今までの合計 35,552
