メインコンテンツにスキップ
Made by GM. It's the eighth generation of a land yacht!
24回答 すべてを表示
Diagram of the fuse box
I can't find the trunk fuse on my Pontiac Bonneville
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I'm having the same problems. Can't find the same fuse box for the car . radio etc.. Someone help up please. I'm no dumbie when it comes to cars. But I'm stuck. Looked everywhere..
Ok. The small fuses are located under the steering wheel where the brake pedal and gas pedal are at.. As far as where the trunk fuse. I can't help there.
さんによる
コメントを追加
1 件の回答
ベストアンサー
@carson_13, benny,Niki , There are two fuse blocks in your vehicle: the driver’s side and passenger’s side fuse blocks and the 3rd is under the hood engine compartment. I believe trunk fuse to be in fuse/relay box passenger side under dash(may be able to access easier by removing glove box liner). Radio fuse shows position 8D, Driver’s side fuse interior block, Pg.6-62/6-63, in the manual link posted below. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://justgivemethedamnmanual.com/wp-c...
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Were would the window fuse be located at in the driver side one or the passenger side fuse boxs
さんによる
コメントを追加
回答を追加する
Niki さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 63
今までの合計 4,986
