メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
727回答 すべてを表示
Why is my xbox one overheating?
I have followed all the steps given to me to ensure it stops over heating but none of which have seemed to work. My xbox one worked the first day I got it and I played it for a couple of hours straight, but the next day it has stopped working. I have moved it to a well ventilated spot and made sure all power cords were properly enabled. I have given it 24 hours to rest / cool down, but it only took 5 minutes for it to over heat again. The power supply cord/ box doesn't feel hot but the xbox one does. Please help me I'm getting really frustrated
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
最も参考になった回答
Your fan could be bad. If you're still under warranty, I'd file a claim and get Microsoft to do it. If not, this may help: Xbox Oneのファンの交換
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I replaced my fan but it still overheats but it use to overheat in 5 minutes know about 1 HR and 40 ish minutes
さんによる
コメントを追加
Buy a ps4. Half the size and runs at 1080. Can't believe xbox one overheats when it's games are limited to 720-912p resolutions
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
http://youtu.be/gNLnyM9p6Ts try doing something like this it really works
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
My x box one is brand new and it overheats 5 minutes after I start to use it. I have moved it away from windows and the sun and still overheats. I was wondering if it would be possible if I could remove the grate that is on top on the right side so it could get air instead of the grates that have small holes in them that allow for no air to enter or escape? Thanks for the help. Bye for now.
さんによる
コメントを追加
回答を追加する
Cody さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 17,673
