メインコンテンツにスキップ
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418回答 すべてを表示
締切られた回答
Cricket wireless/MacBook's fan high rpm
I use a Cricket wireless USB modem and when I'm connected online the rpm and temp are real high. RPM is usually over 6200 and the temp reaches 163F, is this normal? When I quit the wireless and disconnect it from the MacBook, the temp drops along with the rpm.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
The battery is new, about 35 charge cycles on it
さんによる
コメントを追加
1 件の回答
I'm guessing that this modem is powered by USB, which would make it draw power from your MacBook. USB 2.0 can provide a maximum of 5.23V, which could be enough to raise the temperature of your computer by a fair amount.
For more control and monitoring over temperature and fan speed you should take a look at CoolBook.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,137
