Nothing is coming out of the machine
We have this 11 year old machine. Steam is the only thing that is coming out. We had it packed away for many years and just got it out.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If you can't get water to dispense from either the brew head or the steam wand then you may need to force-prime the machine. Using a turkey baster or similar instrument, squeeze water up the tube while the pump is running. Once the water flows through put the tube back into the water tank and allow the boiler to fill completely. Since the machine has sat for several years it might be a good idea to get it tuned up by a professional to make sure it's ready to be used again.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 295
