lg g2 won't turn on, only vibrates
lg g2 won't turn on, only vibrates when i am pressing the power button
Please help
When I had this problem, it was the battery. It was completely dead and required an official charger to charge the phone. Worked fine once it was charging with an official charger.
このアンサーは役に立ちましたか?
I had the same problem, but thank god I'm an Verizon employee. I let it charge all the way and then it worked fine!
このアンサーは役に立ちましたか?
Still vibrate, so there is the power. If the charging LED light come on when plug charger? It's more likely there is something wrong with the LCD screen.
このアンサーは役に立ちましたか?
I dont know, honestly. Ive been having the same problem. None of the above solutions help. It vibrates when charged and when the power is held down. No LEDs turn on, and the screen is just black. The only sign of life from this thing is vibration.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 15
過去 30 日: 22
今までの合計 11,457
1件のコメント
I have the same issue! I replaced the screen and its doing nothing but does vibrate sometimes. So I'm sending the screen back and thinking it may be possible bad replacement part.
rockndave02 さんによる
