My battery life span is very short how can I fix it?
When I have charged my phone overnight my battery drains within hours of removing it from the charger, without me even being very active on my phone. Any suggestions?
Try turning on the battery saver mode on the phone. If this does not work try turning off the location tracker as this also drains a lot of battery. If still facing the same issue try turning off apps that drain a lot of battery such as facebook, or twitter, or it might just be a faulty battery, in which case you need to replace the battery using the LG G2 VS980 Battery Replacement Guide.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 106
