Why is my trigger stuck?
I have enough charge in my battery as indicated by the green lights on the battery, yet my trigger seems to be stuck. What can I do?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You may either have the direction switch in the middle or there is something stuck inside of the chuck.There may be also a bad contact between the battery and the drill,you can check the voltage coming out of the battery.
このアンサーは役に立ちましたか?
Debris may be blocking the path of the trigger. Check for any external debris caught between the trigger and the drill body. If no external debris can be removed, check for internal debris by disassembling the drill.
このアンサーは役に立ちましたか?
This may be caused if the direction switch is in the center position, the trigger is locked and the drill will not function.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,659
