Why aren't my discs firing far?
When I shoot the gun, the discs do not travel as far as they usually do, and sometimes they do not fire at all.
If your discs aren't firing properly, the bolt may be the issue. Try firing the gun with no discs, and if the gun rattles or squeaks, your bolt is probably broken. Reference the bolt replacement guide for more information. Another reason could be that the slide is lodged. Refer to the slide dislodgment guide for solutions. A dirty barrel could also cause faulty disc firing. To clean the barrel, run water through it and remove dirt with toothpicks or cotton swabs.
For more information, reference the Troubleshooting guide.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 105
