I can't get a good reception on the radio?
My radio is turned on and the volume is working, however I cannot seem to get a good sound due to poor reception? How can I get a good signal for the radio?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It sounds like you may be having problems with your antenna. Make sure that the antenna is fully extended and up to get the best reception. You may need to move it around to find the best spot for clear sound. Additionally, the station your are trying to receive may not be strong enough to pick up clearly at your location. Try tuning the radio to a different station to see if you can find one that comes in more clearly. If all of those things don't help you, check out the Troubleshooting page for more tips.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 6
過去 30 日: 7
今までの合計 556
