Power / home bottom is suddenly like pulled into the case...why?
I have my gear fit since July 2014. At the beginning no problems. But at one point 2 months ago- during a flight - I could not press the home bottom anymore as it was like pulled into the case and did not stick out to press on it. In other words- the bottom was kind of even with the rest of the case. I tried all kind of things to get it out again, but nothing really worked. Then, 3 or 4 days later, it seemed like the bottom came out again for some millimeters - not as it was in the beginning but still enough to operate it. I thought - ok it is fixed, but with the next flights the same problem: the bottom gets pulled into the case during the flight and only comes out again after some days.
Is there anything I can do to get it fixed apart from changing the power / home bottom?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
