My HTC M8 won't auto rotate how can I fix this?
I dropped my device and now when I try to turn it into landscape, it won't rotate.
Sounds like a calibration problem. You can re-calibrate the phone by going into settings. Then select "display and gestures" and choose "G-sensor Calibration". Make sure its on a flat surface, though, so it calibrates properly.
このアンサーは役に立ちましたか?
@Jose Estrada Still didn't work for me...
@Jose Estrada Nevermind! Restarting my device and then re-calibrating did the job!
WOW Thanks that worked perfectly.
I have the same problem, when i used your method it helped. Though when i want to move from horizontal mode to vertical mode ot just wont work. Any suggestions?
Thanks alot it's working hooowww
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 17,628
1件のコメント
I am having the same issue and I haven't dropped my phone. My motion sensor stopped working on the lock screen as well.
Matt さんによる
