メインコンテンツにスキップ
LCD Backlight turns off after booting through grey screen
I have a MacBook Pro 15" that I just had the hard drive go bad. I put the new drive in and booted from the install DVD. After the computer boots passed the grey apple screen the backlight turns off. I can see the install menus and successfully reinstalled Leopard without the backlight. Is there a light sensor or lid sensor that may be missing or misaligned after replacing the hard drive that could explain why the backlight turns off? I have closed the lid, put the machine in sleep, attached an external monitor. The backlight doesn't flicker so I really feel like this is something easy I may have overlooked. I have replaced lcd's in laptops before as well as hard drives in MacBooks without this issue.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
3 件のコメント
Tried SMC and PRAM resets ?
さんによる
Is it a sleep issue? Is the HD still spinning? Does touching keys or track pad have any effect?
さんによる
http://www.youtube.com/watch?v=i79zxpXZ5...
This is the youtube link. The screen turns off around the 3 minute mark and I shine a flashlight through the back so you can see the language menu so it is running.
さんによる
コメントを追加
3件の回答
選択されたソリューション
It could be RAM
Try reseating or switching your RAM.
If this answer is acceptable please return and mark it.
Good Luck,
N
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I've tried the SMC and PRAM resets I believe. Isn't that just removing the battery and pressing the power button for 10-15 seconds? Also I don't believe it is a sleep issue as it is a new hard drive and as soon as the Mac boots to the language selection screen the backlight turns off. I'm uploading a video to youtube to show an example and will post the link as soon as possible. If I take a flashlight and shine it through the apple logo I can see the language selection and I can move the mouse to select things.
さんによる
コメントを追加
If this is the same problem I just solved, if you were to plug in an external monitor it would boot to that even though the lid open when you power up the system.
Reason: it thinks the lid is closed. This was due to corrosion on the motherboard interface for the small circuitboard that detects the magnet on the left side of the LCD assembly when the lid is closed. The circuitboard also interfaces with the battery connector and is connected to it with a wiring harness.
You can leave the screws for the battery connector in place but you must remove the keyboard/touchpad assembly then remove the 4 screws that hold the metal bracket in place that sets against the ports that run up the left side of the motherboard. Then you can back the circuitboard out from the motherboard, scrub corrosion off the connector holes on the motherboard and the interface pins on the small circuitboard, plug it back in and you should be good to go!
Happy times.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This is the power inverter, it's pretty cheap on ebay but if you don't know how to change it yourself get a tech to do it. cost me 13 bucks on ebay.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
David Jackman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,857
