Can faulty sensors be replaced?
I have the late model 2013 MBP, and I dropped it (only three feet) at an angler that caused the screen to crack. I bought a replacement on eBay, but didn't read the fine print and discovered that the cables which connect the camera etc. were cut. Ever since then, I've had issues with the GPU sense and another sensor that are all reporting -124 which causes kernel_task to consume more than 600% CPU and the laptop runs slower than molasses. Is there any way to replace these sensors and/or is there a way to tell osx to ignore the sensor readings so I can have the performance back on my MBP?
Thank you for your time.
Mike
この質問は役に立ちましたか?
