Why does my light turn off during usage?
It was dark and I needed to find my glasses that I dropped in the park. While I was searching my light turned off randomly, I found that this happens from time to time.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The Inova microlight is designed to turn off after four minutes of usage when it is on the high setting. This is not a defect, but a function to conserve battery life. Just simply click it back on if you need to continue using the light, or use the second or third mode as they wont turn off after four minutes.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 180
