メインコンテンツにスキップ
Samsung Galaxy Note IIは、大型ディスプレイと一体型自己記憶スタイラス用に最適化されたソフトウェアを組み合わせたスマートフォンでとして知られています。
211回答 すべてを表示
締切られた回答
LCD/LEDs not working, worth replacing?
Okay, before I start, I realized this question might not have a 100% full-proof answer. I'll provide as much detail of the phone as I can.
I bought a broken Galaxy Note II a couple days ago for $20 because it had a broken LCD and a badly cracked digitizer. I thought that at best I would have a fully working phone after replacing the $130-ish LCD, and at worst I would lose $20 (if there was other problems with the phone that were not fixable.) When I went home and tried to charge it, none of the LEDs would turn on and when I connected it to my PC it wouldn't be recognized at all. Basically my question is, if the LCD on a Note II was broken, would there be something stopping the entire phone from starting up and being recognized by a computer? And also, if the LCD was broken bad enough, could that cause the LEDs to stop working?
I just don't want to order the LCD then have to return it if the logic board is fried or something.
Thanks in advance for any help! :)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
The computer can't recognize the phone caused by the lock screen, it's none of the business of broken screen. But the broken screen can't affect the LEDs especially the one to show charging, which means there are some other components wrong.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Like Sophia said. The screen would not affect the charging LEDs. It could however just be a bad battery or charger. I would see if you can get your hands on one of those to rule them out before you buy anything. If either still doesn't work then it is most likely internal damage such as power connection.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for your replies. It's not the cable because I plugged in my sisters' S4 and it worked fine. I guess I'll probably just open it up and see if I can see any problems inside the phone before I order the LCD.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 222
